MUKESH MAKWANA
I have tried to solve hot compression barreling effect, but there are some error coming up and it can't be solved.
  • AniketAniket Forum Coordinator
    edited July 10
     mukeshmakwana: a few suggestions if you don't mind first.
    1. Kindly do not post multiple new discussions for the same query, to avoid cluttering on the student community. Asking this because this is 3rd query for the same/similar question.
    2. Kindly post the appropriate title with your question, Asking this because you are using your name for the title instead of a summary of the question
    3. Kindly post inline images, because Ansys staff can not download images on the student portal, so if you want to reach a larger audience to get answers from, please insert the images inline, instead of attachment that you have done for this thread
    4. Please post a question in as much detail as possible, if you are seeing any error, or seeing something in the solve.out, that would help to steer you in the right direction so kindly post it in the thread, also before posting google the same error message on the community and check if any of the previous threads help you, if it doesn't tell us what you tried which did not work.
    5. Finally, please allow community members some time [2-3 working days] to get back to you.
    Considering these suggestions please modify this thread. I will lock your other threads for bookkeeping.
    -Aniket
