Run Ansys MAPDL using Shared-Memory Parallel
I want to run Ansys with SMP. From the product launcher, this can easily be done from the High Performance Computing Setup tab. However, when I call ansys in batch mode from an external file, it runs using Distributed Computing. So my question is, how I use SMP when calling ansys in batch mode without using the product launcher?
