fluent calculation warning
IbrahimabdullahIbrahimabdullah TaiwanMember
can anyone tell me what went wrong? in addition if i have more than 1.2 million elements my fleunt calculation goes off i dont know why ?? but less than that everything is running smoothly.
thank you
  • edited July 15
    It seems like you have GPU acceleration turned on. The error is basically indicating that your GPU memory is not large enough to fit your computational model when the number of cells is greater than 1.2 million.
    Kalyan
  • IbrahimabdullahIbrahimabdullah TaiwanMember
    edited July 15
    i see .. really appreciate the explanation brother.
    thank you so much
    edited July 15
    do you have any suggestions for converging problems? i sat up 750 iterations but it shows floating point exception after 250 iterations.. i have played around with the URF and i changed the pressure outlet to out flow BC because when i was using pressure outlet i got reverse flow.. the reverse flow issue solved but remaining the floating points problems.
    thank you for your guidance
    edited July 15
    i have attached the residual graph
