Which system to use?
QilahpieQilahpie Member Posts: 2
Hi, i am new to ansys. Say, i want to solve for conduction heat transfer with convection boundary condition assuming steady condition. What is the best system to use? Ansys Fluent or Steady-state thermal? What is the difference exactly?
  • RobRob UKPosts: 8,966Forum Coordinator
    edited July 2020
    Fluent will let you solve the flow so the convective cooling is modelled. In Mechanical you'd need to assign a convective boundary flux or use a fluid element which (I think) then uses a correlation. Mechanical may be quicker, Fluent will be more accurate (assuming you set it up right).
