Defining mass source as mass fraction into density for species transport.
Dear Users
I'm using the species transport module which uses the following equation:
And I want to add source term, which requires units of [kg m^-3 s^-1] and is defined by-
Source = -2[s^-1] * MassFraction * Density
And I'm adding it through Fluent Expressions, but is giving some error and the fluent automatically closes immediately as I hit OK.
How to resolve this problem??
And if I exclude MassFraction (which has no units) from the source expression, then the simulation runs fine. But in my problem, I need to include this MassFraction term.
    edited July 22
    MassFraction of what? Can you try including the scope of the variable?
  • mettusagarmettusagar Member
    edited July 22
    I've defined two fluids in the materials:
    first fluid = nanoparticle
    2nd fluid = water
    And the mixture of both the fluids (let's say fluid_1) by specifying the mass fraction of nanoparticle in water.
    I'm trying to flow fluid_1 [nanoparticles + water] in a domain which is initially containing only water, which means MassFraction of nanoparticle is zero initially in the flow domain.
    And the flow will be governed by the convection-diffusion Process. So, I'm using Species Transport Model in Ansys fluent.
    But there is a source in my problem, which I need to include and I’m adding it through Parameter Expressions.
    It gave the Error shown in the above picture and then the fluent window automatically closed.
    mettusagar
    mettusagar
    edited July 22
    MassFraction only is wrong you need to provide the scope MassFraction(species='h2o') for example
    edited July 22
    Can you please tell, how can I define the scope.
    And do I need to define it in Parameter Expressions??
    mettusagar
    edited July 22
    Just use the expression first before doing any parameter. The scope either you do it manualyy or you select it from the variable lists in the expression manager (I am using the release 2020r2).
    edited July 22
    Hello Amine
    I couldn't see any option for giving scope in the variables and don't know how to give it manually. Can you please help me out?
    That how can I give it manually, because it's nowhere mentioned in any help manual.
    edited July 22
    Under Species you find it or copy the expression I shared...
    edited July 22
    Is this the expression? -
    And do I need to enter the name of the fluid in between single quotes.
    Thanks and regards,
    mettusagar
    edited July 22
    edited July 23
    Hello Amine
    I tried the suggestion given by you of including the scope of MassFraction and entered the expression as:
    Source = -2[s^-1]*MassFraction(species='nano-particle<n>')*Density
    But still, it is giving error:
    The steps I followed:
    edited July 23
    So that is the way to define the expression. Which version are you using? Is UDF an alternative? Can you check in the Expression Managers under Variables>Species and look after the MassFraction of your specie?
    edited July 23
    Hello Amine
    I'm using Ansys 2019 R3 version.
    I'm getting only this option under species>Mass fraction of
    And when I click Mass fraction of, then it only enters word MassFraction, and scope I'd given manually.
    <img src="data:image/png;base64,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
    edited July 23
    Okay you are working with an old version. The context specification is actually the same. Double Check please with the help.
  • mettusagarmettusagar Member
    edited July 23
    Hello Amine
    I agree that context is same, but under species, there is no provision or option for including the scope of MassFraction, which I'd to include manually later.
    And copying that expression given by you, actually worked, because earlier the fluent window closed when I included the MassFraction without defining scope.
    And by including scope, it takes expression successfully but the error is getting while running the simulation.
    edited July 23
    So then we cannot help here: you might give it a try with a simple UDF to check if it is working at all. By the way you need to provide the same source term for species equation.
    edited July 23
    Hello Amine
    I haven't used UDF much. Density and the constant term, that I will include with the help of the manual.
    Can you please tell that how can I include MassFraction in the UDF?
    Thanks and regards
    mettusagar
    edited July 23
    I can tell refer to the Customizatiopn Manual it contains a lot of examples. First of all here try with constant input for both equations continuity and species if it is running at all. Moreover your source term looks a bit odd: is it really so defined??
    edited July 23
    Hello Amine
    In actual I've to solve the following equation, but there is not any direct provision for solving in terms of concentration.
     where C = concentration, Source = -kb.C
    But species transport module uses the following equation which uses massfraction and density rather than concentration. and the rest terms are same as of above equaiton.
    where
    So, I converted concentration into massfraction, as I already know the density of mixture and then gave the input values for simulation.
    One another option:
    Can I use "User Defined Scalar" for directly solving the 1st equation which contains concentration terms ?
    As in my problem, the fluid domain is also porous. So, I also have to give porosity to the fluid domain.
    If yes, can I give porosity for the flow domain in cell zone conditions for the equation to be solved by  "User Defined Scalar" ?
    • And also do I need to give the velocity which is represented by 'u' in the equation -  in the UDS code or in the boundary conditions ?
    • And also the term 'D'  which represents diffusivity, where can I define it - in the material properties or in the UDS code ?
    Thanks and regards
    mettusagar
    edited July 24
    1/You can use UDS
    2/That is independent of UDS equation. Refer to the equation solved in the manual.
    edited July 24
    3/u is the convective velocity: it is not an input (unless you want to modifiy it)
    4/Yes you can.
