Stratified wall shear on a circular cylinder
Dear all,
Does anyone know the reason of the stratified wall shear stress on a circular cylinder as shown in the picture? The wall shear stress should be continuous on the cylinder surface. I used turbulence model of k-w SST and created mesh from ICEM in ANSYS. Thanks!
Best regards
Allen
  • KremellaKremella Forum Coordinator
    edited July 27
    Could you please embed your screenshot directly in your post? We are not able to download attachments from the community.
    Thanks.
    Might be related to mesh-to-surface projection in ICEM:
    already test what happens when either Settings>Meshing Options>Hexa Meshing>Project to bisplines is enabled or a tighter (e.g. 1e-5/1e-6) value for Settings>Model>Triangulation Tolerance has been set?
