Fourier number is a dimensionless group which arises from the non-dimensionalization of the conduction equation. It is a measure of heat conducted through a body relative to the heat stored. Fourier number characterizes the time scales in conduction problem. Biot number on the other hand is the ratio of the internal resistance of a body to heat conduction to its external resistance to heat convection. For more details on Biot number please check out the post related to lumped capacitance model on the forum.
Hi @prajput ,
