Condensation is the process of a substance in a gaseous state transforming into a liquid state. This change is caused by a change in pressure and temperature of the substance.
Vaporization is the process that occurs when a chemical or element is converted from a liquid or a solid to a gas. When a liquid is converted to a gas, the process is called evaporation or boiling; when a solid is converted to a gas, the process is called sublimation.
Hello @kkanade
