Whats the difference between sensible heat and latent heat?
akhemkaakhemka Forum Coordinator Posts: 19
Whats the difference between sensible heat and latent heat??
  • AkismetAkismet Posts: 36Admin
    Hello @akhemka
    Sensible heat refers to the thermal energy needed for changing the temperature of an object.On the other hand, in the case of Latent heat, there is no change in temperature. It simply refers to the thermal energy that is released or absorbed by a substance during a change in its physical state at the same temperature.
