Supersonic aircrafts speed is often measured in Mach, what is that?
kkanadekkanade Forum Coordinator
  • Hi @kkanade  !
    The Mach number is defined as the ratio of the flow velocity (V) to the speed of sound (c):
    M = V/c
    This number defines whether a flow or vehicle is moving at subsonic (M<1), sonic (M=1), or supersonic (M>1) speed. Namely, whether is traveling slower, at the same speed, or faster than the speed of sound.
    If a vehicle travels at Mach 2 it means that is moving at twice the speed of sound.
    Hi @prajput  ,
    How much is the speed of sound?
  • Hello @kkanade , allow me to answer this one,
    The speed of sound does not have a specific value but it depends on the medium. Indeed, it represents the velocity of propagation of a sound wave through a medium. Its more general expression, valid for all gases, is:
    a = sqrt[ (dp/drho)_s ]
    where s indicates an isentropic process.
    A more commonly used expression, for the speed of sound, is the one for calorically perfect gases:
    a = sqrt( gamma*R*T)
    where
    gamma is the ratio of the specific heats
    R is the specific gas constant
    T is the medium temperature
    Hope that answers your question! 😎
