Viscosity is the measure of the fluid resistance to deformation. When fluids move they tend to deform continuously. This is due to some internal forces (or better stresses) that we can call shear stresses. For some fluids, the deformation is proportional to the magnitude of the shear stresses. These fluids are known as 'Newtonian Fluids'. The SI units of viscosity are kg / (m s) or (Pa s).
Have a look at our Ansys Innovation Courses. In particular you check out these two courses that discuss about viscosity:
Hi @prajput , the definition provided by my colleague is for the dynamic viscosity of the fluid. When you divide this number with the fluid density, you will obtain the kinematic viscosity.
What Are Fluids? | Ansys Innovation Courses
https://courses.ansys.com/index.php/courses/what-are-fluids/Exploring the Physics of Drag | Ansys Innovation Courses
https://courses.ansys.com/index.php/courses/exploring-drag-and-physics/Thank you for the response! Why are there two types of viscosities? How do you differentiate between them?
Thank you!
Mathematically,
nu = mu / rho
where,
nu refers to kinematic viscosity,
mu refers to dynamic viscosity, and
rho refers to fluid density
The SI unit is m^2/s.
Thank you.🙂
