Antenna Propagation - Uniform Array
What type of arrays can be classified as a uniform linear array?
Thanks in advance.
  • cblaircblair Forum Coordinator
    A Uniform Linear Array (ULA) is any set of equally spaced radiating antenna element. The element also has to be oriented in the same direction. Equal spacing and identical orientation should yield equal magnitude and phase between each element.
  • So, can a phased-array be considered as uniform linear array?
    Hi - A phased array can be created in many forms. A uniform linear array has its elements equally spaced with equal phase difference. This means a special case of a phased array can be a uniform linear array but a phased array is not always a linear array.
