1. Because it is rotating - It will have friction and windage loses. Transformer has no moving parts
2. Because there is an air gap between stator and rotor - This increases the mmf and magnetizing current to push the magnetic flux overcoming the air gap reluctance. The additional mmf needs to be supplied from the input supply
All Lumerical installation and licensing questions should be posted in the Ansys Products Installation category.
There are two reasons for this
