Errors - Reinforced Concrete Beam
Dear all,
Attached are two errors that I encounter when modelling the beam using the Finite Element Method (FEM). May I ask for some suggestions and help with those problems?
The first error is regarding the converge on a solution for the nonlinear problem. May I know why will this happen and how to solve it?
The second error is regarding an internal solution magnitude limit was exceeded. Is that mean that the load applied to the beam was too large or exceed the ultimate load?
Thank you in advance.
Joseph
  • edited July 2018
    Hi Joseph,
    In finite element analyses, all the components are expected to be fully constrained to ensure that the applied forces and the internal forces will balance each other out. The reaction force always follows stiffness and constraints, if there is neither of them to resist an applied force, it results in rigid body motion.
    When a model is not fully constrained in Static structural analysis, the solver throws out pivoting error, or errors related to a certain degree of freedom (DOF) exceeding limits. Four ways for identifying the unconstrained body are:
    1. If the message appears under the WB messages, right click on the message > Go to Object will take you to the part under Geometry Tree.
    2. Identify the node based on the node number provided in the error message. In case the node number is not available in the mesh, it must be an internal node created by Mechanical for features such as remote points, or bolt pretension.
    3. Perform a modal analysis on the assembly to identify if there are any 0 Hz (or near zero) modes. If such modes are identified, plot the mode shapes for those modes to identify which parts are free floating.
    4. Turn on the Newton-Raphson residuals under Solution information prior to running the model and check the contours for residuals, typically when a part is not constrained, the residuals are distributed all over the problematic part.
    Possible Solutions:
    • Once you identify the part, check how is the part supposed to be held in place in the actual physical application.
    • If the internal forces are expected to be self-balancing due to symmetry (e.g., free thermal expansion of parts), then use weak springs (turn it ON under Analysis Settings) or inertial relief for linear models (small deformation, linear materials, linear contacts).
    In case the part is to be held in place by contacts:
    Linear contacts (bonded and no separation):
    • make sure that there are no initial gaps or penetrations between the parts.
    • If there are any, manually define pinball radius so that it is larger than the gap/penetration. Also, use MPC formulation if there are no other MPC based constraints in the vicinity.
    • Mesh in the contact region is fine enough.
    Nonlinear contacts (frictionless, frictional and rough):
    • Change the contact type to Bonded to see if that fixes the issue. If it does, proceed to the following steps. If not, check if the steps listed under linear contacts resolve the issue. If yes, then proceed with the following steps. • If gap is negligibly small, consider using the Interface Treatment Option "Adjust to Touch" to close the gap.
    • Use a small amount of friction so that part will not slide away during loading.
    • In case of force or pressure loading, use smaller initial timestep, increase a pinball radius.
    • If the issue persists, define contact stabilization damping (use a small value such as 5e-2).
    • In case of internal nodes such a bolt pretension, make sure that there is no conflicting constraint equation based definition (e.g., scoped surface sharing bolt pretension and symmetry conditions).
  • sruthyvssruthyvs Member
    edited April 30
    I an a newbie to ansys. I need to design a soil pile continuum model in ansys 19.2.I am using a licensed software. I have created a concrete circular single end bearing pile of 500mm Dia and 12m depth in a soil block of 10*10*12 having 5 soil layers of sand and clay..... Including 6 main rebars... 17 top stirrups and... 11 bottom stirrups. I am doing this work to get this settlement analysis in Mohr coulumb model. I found issue in dealing with connections and contacts. I have given bonded connection for steel to concrete, steel rft with stirrups, bw soil layer and frictional contact with coefficient 0.2 for concrete to soil connections. But there occurred problems of overlapping and penetration.... I have just created a default mesh having 0.67m element size with 204484 elements and 981245 nodes with 40 bodies of total... A remote force of - 90Ton but m not getting the total and directional deformation... Saying an unknown error.... And CPU time elapsed..... I am using an i7 lap with 16gb ram and graphics card.... Please help me out to sort out my problem.... I jzt need information on assigning contacts and mesh. I have created contact tool... But some of the contacts are seen inactive and one contact is bonded and closed but has a large amount of penetration and gap? I don't know what it means and how can I solve this.... I just wanna find the soil settlement ie deformation of soil and pile as a whole....
    sir could you plz help me to sort out my errors while doing the ansys project.
    ANSYS Mechanical Enterprise
     |   W E L C O M E   T O   T H E   A N S Y S (R)  P R O G R A M     |
     *            ANSYS Release 19.2     LEGAL NOTICES             *
     * Copyright 1971-2018 ANSYS, Inc.  All rights reserved.       *
     * Unauthorized use, distribution or duplication is            *
     * prohibited.                                                 *
     * Ansys is a registered trademark of ANSYS, Inc. or its       *
     * subsidiaries in the United States or other countries.       *
     * See the ANSYS, Inc. online documentation or the ANSYS, Inc. *
     * documentation CD or online help for the complete Legal      *
     * Notice.                                                     *
     * THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION       *
     * INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY      *
     * PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS.    *
     * The software products and documentation are furnished by    *
     * ANSYS, Inc. or its subsidiaries under a software license    *
     * agreement that contains provisions concerning               *
     * non-disclosure, copying, length and nature of use,          *
     * compliance with exporting laws, warranties, disclaimers,    *
     * limitations of liability, and remedies, and other           *
     * provisions.  The software products and documentation may be *
     * used, disclosed, transferred, or copied only in accordance  *
     * with the terms and conditions of that software license      *
     * agreement.                                                  *
     * ANSYS, Inc. is a UL registered                              *
     * ISO 9001:2008 company.                                      *
     * This product is subject to U.S. laws governing export and   *
     * re-export.                                                  *
     * For U.S. Government users, except as specifically granted   *
     * by the ANSYS, Inc. software license agreement, the use,     *
     * duplication, or disclosure by the United States Government  *
     * is subject to restrictions stated in the ANSYS, Inc.        *
     * software license agreement and FAR 12.212 (for non-DOD      *
     * licenses).                                                  *
     Release 19.2
     Point Releases and Patches installed:
     ANSYS, Inc. Products Release 19.2
     SpaceClaim Release 19.2
     AIM Release 19.2
     Autodyn Release 19.2
     LS-DYNA Release 19.2
     CFD-Post only Release 19.2
     CFX (includes CFD-Post) Release 19.2
     Chemkin Release 19.2
     EnSight Release 19.2
     FENSAP-ICE Release 19.2
     Fluent (includes CFD-Post) Release 19.2
     Forte Release 19.2
     Polyflow (includes CFD-Post) Release 19.2
     TurboGrid Release 19.2
     ICEM CFD Release 19.2
     Aqwa Release 19.2
     Customization Files for User Programmable Features Release 19.2
     Mechanical Products Release 19.2
     Icepak (includes CFD-Post) Release 19.2
     Remote Solve Manager Standalone Services Release 19.2
     Viewer Release 19.2
     ACIS Geometry Interface Release 19.2
     AutoCAD Geometry Interface Release 19.2
     Catia, Version 4 Geometry Interface Release 19.2
     Catia, Version 5 Geometry Interface Release 19.2
     Catia, Version 6 Geometry Interface Release 19.2
     Creo Elements/Direct Modeling Geometry Interface Release 19.2
     Creo Parametric Geometry Interface Release 19.2
     Inventor Geometry Interface Release 19.2
     JTOpen Geometry Interface Release 19.2
     NX Geometry Interface Release 19.2
     Parasolid Geometry Interface  Release 19.2
     Solid Edge Geometry Interface Release 19.2
     SOLIDWORKS Geometry Interface Release 19.2
     ANSYS, Inc. License Manager Release 19.2
              *****  ANSYS COMMAND LINE ARGUMENTS  *****
      BATCH MODE REQUESTED (-b)    = NOLIST
      INPUT FILE COPY MODE (-c)    = COPY
      DISTRIBUTED MEMORY PARALLEL REQUESTED
           2 PARALLEL PROCESSES REQUESTED WITH SINGLE THREAD PER PROCESS
        TOTAL OF     2 CORES REQUESTED
      MPI OPTION                   = INTELMPI
      INPUT FILE NAME              = F:\SD\WORKSPACE\MINI-PROJECT ANSYS WORK\ANSYS WORK (05-04-2020)\SOIL-PILE MODEL TRIAL 1\SOIL MODEL WITH MANUAL CONTACTS 30-04-2020\600mm DIAMETER\_ProjectScratch\ScrF9B3\dummy.dat
      OUTPUT FILE NAME             = F:\SD\WORKSPACE\MINI-PROJECT ANSYS WORK\ANSYS WORK (05-04-2020)\SOIL-PILE MODEL TRIAL 1\SOIL MODEL WITH MANUAL CONTACTS 30-04-2020\600mm DIAMETER\_ProjectScratch\ScrF9B3\solve.out
      START-UP FILE MODE           = NOREAD
      STOP FILE MODE               = NOREAD
     RELEASE= Release 19.2         BUILD= 19.2      UP20180808   VERSION=WINDOWS x64
     CURRENT JOBNAME=file0  112:46  APR 30, 2020 CP=      0.172
     PARAMETER _DS_PROGRESS =     999.0000000
     /INPUT FILE= ds.dat  LINE=       0
     *** NOTE ***                            CP =       0.297   TIME= 112:46
     The /CONFIG,NOELDB command is not valid in a Distributed ANSYS
     solution.  Command is ignored.
     *GET  _WALLSTRT  FROM  ACTI  ITEM=TIME WALL  VALUE=  11.5461111
     TITLE=
     TRIAL-1(600mm dia)--Static Structural (B5)
     SET PARAMETER DIMENSIONS ON  _WB_PROJECTSCRATCH_DIR
      TYPE=STRI  DIMENSIONS=      248        1        1
     PARAMETER _WB_PROJECTSCRATCH_DIR(1) = F:\SD\WORKSPACE\MINI-PROJECT ANSYS WORK\ANSYS WORK (05-04-2020)\SOIL-PILE MODEL TRIAL 1\SOIL MODEL WITH MANUAL CONTACTS 30-04-2020\600mm DIAMETER\_ProjectScratch\ScrF9B3\
     SET PARAMETER DIMENSIONS ON  _WB_SOLVERFILES_DIR
     PARAMETER _WB_SOLVERFILES_DIR(1) = F:\SD\WORKSPACE\MINI-PROJECT ANSYS WORK\ANSYS WORK (05-04-2020)\SOIL-PILE MODEL TRIAL 1\SOIL MODEL WITH MANUAL CONTACTS 30-04-2020\600mm DIAMETER\TRIAL-1(600mm dia)_files\dp0\SYS-1\MECH\
     SET PARAMETER DIMENSIONS ON  _WB_USERFILES_DIR
     PARAMETER _WB_USERFILES_DIR(1) = F:\SD\WORKSPACE\MINI-PROJECT ANSYS WORK\ANSYS WORK (05-04-2020)\SOIL-PILE MODEL TRIAL 1\SOIL MODEL WITH MANUAL CONTACTS 30-04-2020\600mm DIAMETER\TRIAL-1(600mm dia)_files\user_files\
     --- Data in consistent MKS units. See Solving Units in the help system for more
     MKS UNITS SPECIFIED FOR INTERNAL
      LENGTH        (l)  = METER (M)
      MASS          (M)  = KILOGRAM (KG)
      TIME          (t)  = SECOND (SEC)
      TEMPERATURE   (T)  = CELSIUS (C)
      TOFFSET            = 273.0
      CHARGE        (Q)  = COULOMB
      FORCE         (f)  = NEWTON (N) (KG-M/SEC2)
      HEAT               = JOULE (N-M)
      PRESSURE           = PASCAL (NEWTON/M**2)
      ENERGY        (W)  = JOULE (N-M)
      POWER         (P)  = WATT (N-M/SEC)
      CURRENT       (i)  = AMPERE (COULOMBS/SEC)
      CAPACITANCE   (C)  = FARAD
      INDUCTANCE    (L)  = HENRY
      MAGNETIC FLUX      = WEBER
      RESISTANCE    (R)  = OHM
      ELECTRIC POTENTIAL = VOLT
     INPUT  UNITS ARE ALSO SET TO MKS
     *** ANSYS - ENGINEERING ANALYSIS SYSTEM  RELEASE Release 19.2     19.2     ***
     DISTRIBUTED ANSYS Mechanical Enterprise
     00000000  VERSION=WINDOWS x64   112:46  APR 30, 2020 CP=      0.297
              ***** ANSYS ANALYSIS DEFINITION (PREP7) *****
     *********** Nodes for the whole assembly ***********
     *********** Elements for Body 1 "MEDIUM  SAND 2" ***********
     *********** Elements for Body 2 "MEDIUM SAND 1" ***********
     *********** Elements for Body 3 "SILTY SANDY CLAY 3" ***********
     *********** Elements for Body 4 "SILTY SANDY CLAY 2" ***********
     *********** Elements for Body 5 "SILTY SANDY CLAY 1" ***********
     *********** Elements for Body 6 "CONCRETE-PILE" ***********
     *********** Elements for Body 7 "TOP STIRRUPS 1" ***********
     *********** Elements for Body 8 "TOP STIRRUPS 2" ***********
     *********** Elements for Body 9 "TOP STIRRUPS 3" ***********
     *********** Elements for Body 10 "TOP STIRRUPS 4" ***********
     *********** Elements for Body 11 "TOP STIRRUPS 5" ***********
     *********** Elements for Body 12 "TOP STIRRUPS 6" ***********
     *********** Elements for Body 13 "TOP STIRRUPS 7" ***********
     *********** Elements for Body 14 "TOP STIRRUPS 8" ***********
     *********** Elements for Body 15 "TOP STIRRUPS 9" ***********
     *********** Elements for Body 16 "TOP STIRRUPS 10" ***********
     *********** Elements for Body 17 "TOP STIRRUPS 11" ***********
     *********** Elements for Body 18 "TOP STIRRUPS 12" ***********
     *********** Elements for Body 19 "TOP STIRRUPS 13" ***********
     *********** Elements for Body 20 "TOP STIRRUPS 14" ***********
     *********** Elements for Body 21 "TOP STIRRUPS 15" ***********
     *********** Elements for Body 22 "TOP STIRRUPS 16" ***********
     *********** Elements for Body 23 "TOP STIRRUPS 17" ***********
     *********** Elements for Body 24 "BOTTOM STIRRUPS 1" ***********
     *********** Elements for Body 25 "BOTTOM STIRRUPS 2" ***********
     *********** Elements for Body 26 "BOTTOM STIRRUPS 3" ***********
     *********** Elements for Body 27 "BOTTOM STIRRUPS 4" ***********
     *********** Elements for Body 28 "BOTTOM STIRRUPS 5" ***********
     *********** Elements for Body 29 "BOTTOM STIRRUPS 6" ***********
     *********** Elements for Body 30 "BOTTOM STIRRUPS 7" ***********
     *********** Elements for Body 31 "BOTTOM STIRRUPS 8" ***********
     *********** Elements for Body 32 "BOTTOM STIRRUPS 9" ***********
     *********** Elements for Body 33 "BOTTOM STIRRUPS 10" ***********
     *********** Elements for Body 34 "BOTTOM STIRRUPS 11" ***********
     *********** Elements for Body 35 "MAIN LONG REBARS 1" ***********
     *********** Elements for Body 36 "MAIN LONG REBARS 2" ***********
     *********** Elements for Body 37 "MAIN LONG REBARS 3" ***********
     *********** Elements for Body 38 "MAIN LONG REBARS 4" ***********
     *********** Elements for Body 39 "MAIN LONG REBARS 5" ***********
     *********** Elements for Body 40 "MAIN LONG REBARS 6" ***********
     *********** Send User Defined Coordinate System(s) ***********
     *********** Set Reference Temperature ***********
     *********** Send Materials ***********
     *********** Create Contact "Frictional - CONCRETE-PILE To Multiple" ***********
                 Real Constant Set For Above Contact Is 42 & 41
     *********** Create Contact "Bonded - MEDIUM  SAND 2 To MEDIUM SAND 1" *********
                 Real Constant Set For Above Contact Is 44 & 43
     *********** Create Contact "Bonded - MEDIUM SAND 1 To SILTY SANDY CLAY 3" *****
                 Real Constant Set For Above Contact Is 46 & 45
     *********** Create Contact "Bonded - SILTY SANDY CLAY 3 To SILTY SANDY CLAY 2"
                 Real Constant Set For Above Contact Is 48 & 47
     *********** Create Contact "Bonded - SILTY SANDY CLAY 2 To SILTY SANDY CLAY 1"
                 Real Constant Set For Above Contact Is 50 & 49
     *********** Create Contact "Bonded - CONCRETE-PILE To Multiple" ***********
                 Real Constant Set For Above Contact Is 52 & 51
     *********** Create Contact "Bonded - Multiple To Multiple" ***********
                 Real Constant Set For Above Contact Is 54 & 53
     *********** Fixed Supports ***********
     *********** Define Pressure Using Surface Effect Elements ***********
     ***** ROUTINE COMPLETED *****  CP =         6.219
     --- Number of total nodes = 975357
     --- Number of contact elements = 547031
     --- Number of spring elements = 0
     --- Number of bearing elements = 0
     --- Number of solid elements = 202818
     --- Number of condensed parts = 0
     --- Number of total elements = 749849
     *GET  _WALLBSOL  FROM  ACTI  ITEM=TIME WALL  VALUE=  11.5472222
     *************************    SOLUTION       ********************************
     *****  ANSYS SOLUTION ROUTINE  *****
     PERFORM A STATIC ANALYSIS
      THIS WILL BE A NEW ANALYSIS
     LARGE DEFORMATION ANALYSIS
     USE SPARSE MATRIX DIRECT SOLVER
     CONTACT INFORMATION PRINTOUT LEVEL       1
     DO NOT COMBINE ELEMENT MATRIX FILES (.emat) AFTER DISTRIBUTED PARALLEL SOLUTION
     DO NOT COMBINE ELEMENT SAVE DATA FILES (.esav) AFTER DISTRIBUTED PARALLEL SOLUTION
     NLDIAG: Nonlinear diagnostics CONT option is set to ON.
             Writing frequency : each ITERATION.
     DEFINE RESTART CONTROL FOR LOADSTEP LAST
     AT FREQUENCY OF LAST AND NUMBER FOR OVERWRITE IS    0
     DELETE RESTART FILES OF ENDSTEP
     ******************* SOLVE FOR LS 1 OF 1 ****************
     SELECT       FOR ITEM=TYPE COMPONENT=
      IN RANGE        55 TO         55 STEP          1
            147  ELEMENTS (OF     749849  DEFINED) SELECTED BY  ESEL  COMMAND.
     SELECT      ALL NODES HAVING ANY ELEMENT IN ELEMENT SET.
            488 NODES (OF     975357  DEFINED) SELECTED FROM
          147 SELECTED ELEMENTS BY NSLE COMMAND.
     GENERATE SURFACE LOAD PRES ON SURFACE DEFINED BY ALL SELECTED NODES
     VALUES=  346840.000      0.00000000
     NUMBER OF PRES ELEMENT FACE LOADS STORED =        147
     ALL SELECT   FOR ITEM=NODE COMPONENT=
      IN RANGE         1 TO     975357 STEP          1
         975357  NODES (OF     975357  DEFINED) SELECTED BY NSEL  COMMAND.
     ALL SELECT   FOR ITEM=ELEM COMPONENT=
      IN RANGE         1 TO     749849 STEP          1
         749849  ELEMENTS (OF     749849  DEFINED) SELECTED BY  ESEL  COMMAND.
     PRINTOUT RESUMED BY /GOP
     USE AUTOMATIC TIME STEPPING THIS LOAD STEP
     USE       1 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL  DEGREES OF FREEDOM
     FOR AUTOMATIC TIME STEPPING:
       USE     10 SUBSTEPS AS A MAXIMUM
       USE      1 SUBSTEPS AS A MINIMUM
     TIME=  1.0000
     ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.
     WRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE
       FOR ALL APPLICABLE ENTITIES
     WRITE NSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
     WRITE RSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
     WRITE STRS ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
     WRITE EPEL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
     WRITE EPPL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
     NONLINEAR STABILIZATION CONTROL:
     KEY=OFF
     *GET  ANSINTER_  FROM  ACTI  ITEM=INT        VALUE=  0.00000000
     *IF  ANSINTER_                         ( =   0.00000     )  NE
          0                                 ( =   0.00000     )  THEN
     *ENDIF
     *** NOTE ***                            CP =       7.531   TIME= 112:51
     The automatic domain decomposition logic has selected the MESH domain
     decomposition method with 2 processes per solution.
     *****  ANSYS SOLVE    COMMAND  *****
     *** WARNING ***                         CP =       7.875   TIME= 112:51
     Element shape checking is currently inactive.  Issue SHPP,ON or
     SHPP,WARN to reactivate, if desired.
     *** NOTE ***                            CP =       8.375   TIME= 112:52
     The model data was checked and warning messages were found.
      Please review output or errors file ( F:\SD\WORKSPACE\MINI-PROJECT
     DIAMETER\_ProjectScratch\ScrF9B3\file0.err ) for these warning
     messages.
     *** SELECTION OF ELEMENT TECHNOLOGIES FOR APPLICABLE ELEMENTS ***
          --- GIVE SUGGESTIONS AND RESET THE KEY OPTIONS ---
     ELEMENT TYPE    1 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
      KEYOPT(1-12)=    0    0    0    0    0    0    0    0    0    0    0    0
     ELEMENT TYPE    2 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
     ELEMENT TYPE    3 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
     ELEMENT TYPE    4 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
     ELEMENT TYPE    5 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
     ELEMENT TYPE    6 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
     ELEMENT TYPE    7 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     HYPERELASTIC MATERIALS. NO SUGGESTION IS AVAILABLE AND NO RESETTING IS NEEDED.
     ELEMENT TYPE    8 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE    9 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   10 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   11 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   12 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   13 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   14 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   15 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   16 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   17 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   18 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   19 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   20 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   21 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   22 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   23 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   24 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   25 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   26 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   27 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   28 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   29 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   30 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   31 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   32 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   33 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   34 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
     ELEMENT TYPE   35 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
     ELEMENT TYPE   36 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
     ELEMENT TYPE   37 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
     ELEMENT TYPE   38 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
     ELEMENT TYPE   39 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
     ELEMENT TYPE   40 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
     00000000  VERSION=WINDOWS x64   112:52  APR 30, 2020 CP=      8.516
                           S O L U T I O N   O P T I O N S
       PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D
       DEGREES OF FREEDOM. . . . . . UX   UY   UZ
       ANALYSIS TYPE . . . . . . . . . . . . . . . . .STATIC (STEADY-STATE)
       OFFSET TEMPERATURE FROM ABSOLUTE ZERO . . . . .  273.15
       NONLINEAR GEOMETRIC EFFECTS . . . . . . . . . .ON
       EQUATION SOLVER OPTION. . . . . . . . . . . . .SPARSE
       PLASTIC MATERIAL PROPERTIES INCLUDED. . . . . .YES
       NEWTON-RAPHSON OPTION . . . . . . . . . . . . .PROGRAM CHOSEN
       GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .SYMMETRIC
     *** WARNING ***                         CP =       9.578   TIME= 112:53
     Material number 55 (used by element 749703) should normally have at
     least one MP or one TB type command associated with it.  Output of
     energy by material may not be available.
     *** NOTE ***                            CP =       9.719   TIME= 112:53
     The step data was checked and warning messages were found.
     messages.
     This nonlinear analysis defaults to using the full Newton-Raphson
     solution procedure.  This can be modified using the NROPT command.
     The conditions for direct assembly have been met.  No .emat or .erot
     files will be produced.
     *** NOTE ***                            CP =      18.500   TIME= 113:02
     The initial memory allocation (-m) has been exceeded.
      Supplemental memory allocations are being used.
     Memory resident data base increased from      1024 MB to      2048 MB.
     *** NOTE ***                            CP =      33.484   TIME= 113:17
     Symmetric Deformable- deformable contact pair identified by real
     constant set 41 and contact element type 41 has been set up.  The
     companion pair has real constant set ID 42.  Both pairs should have
     the same behavior.
     ANSYS will keep the current pair and deactivate its companion pair,
     resulting in asymmetric contact.
     Contact algorithm: Augmented Lagrange method
     Contact detection at: Gauss integration point
     Contact stiffness factor FKN                  1.0000
     The resulting initial contact stiffness      0.44683E+10
     Default penetration tolerance factor FTOLN   0.10000
     The resulting penetration tolerance          0.37662E-02
     Max. initial friction coefficient MU         0.20000
     Default tangent stiffness factor FKT          1.0000
     Default elastic slip factor SLTOL            0.10000E-01
     The resulting elastic slip tolerance         0.67866E-03
     Update contact stiffness at each iteration
     Default Max. friction stress TAUMAX          0.10000E+21
     Average contact surface length               0.67866E-01
     Average contact pair depth                   0.37662E-01
     Default pinball region factor PINB            2.0000
     The resulting pinball region                 0.75324E-01
     Auto contact offset used to close gap         0.0000
     Initial penetration is excluded.
     Max.  Initial penetration 1.331797793E-03 was detected between contact
     element 209964 and target element 216792.
     You may move entire target surface by : x= -1.327201114E-03, y=
     1.807172058E-18, z= 1.10555704E-04,to reduce initial penetration.
     constant set 42 and contact element type 41 has been set up.  The
     companion pair has real constant set ID 41.  Both pairs should have
     the same behavior.
     ANSYS will deactivate the current pair and keep its companion pair,
     The resulting penetration tolerance          0.33540E-01
     The resulting elastic slip tolerance         0.35908E-02
     Average contact surface length               0.35908
     Average contact pair depth                   0.33540
     The resulting pinball region                 0.67081
     One of the contact searching regions contains at least 768 target
     elements.  You may reduce the pinball radius.
     Max.  Initial penetration 1.218320269E-03 was detected between contact
     element 214856 and target element 206549.
     You may move entire target surface by : x= -1.016706124E-03, y=
     -3.564265712E-20, z= -6.712770927E-04,to reduce initial penetration.
     constant set 43 and contact element type 43 has been set up.  The
     companion pair has real constant set ID 44.  Both pairs should have
     the same behavior.
     Small sliding logic is assumed
     The resulting initial contact stiffness      0.39111E+10
     The resulting penetration tolerance          0.40909E-01
     Default opening contact stiffness OPSF will be used.
     Default elastic slip factor SLTOL            0.50000E-02
     The resulting elastic slip tolerance         0.20307E-02
     Average contact surface length               0.40615
     Average contact pair depth                   0.40909
     Default pinball region factor PINB           0.50000
     The resulting pinball region                 0.20455
     Initial penetration/gap is excluded.
     Bonded contact (always) is defined.
     Max.  Initial penetration 1.776356839E-15 was detected between contact
     element 218125 and target element 218239.
     constant set 44 and contact element type 43 has been set up.  The
     companion pair has real constant set ID 43.  Both pairs should have
     the same behavior.
     The resulting elastic slip tolerance      &n
