Battery Pack Simulation - Twin Builder
prajputprajput Admin Posts: 98
I'm thinking of working on simulating a battery pack. In what ways can Twin Builder be used for modeling a battery pack?
Looking forward to your comments.
  • Kalyan GoparajuKalyan Goparaju Posts: 236Member
    If you have HPPC data from test or if you already have identified parameters for a battery Equivalent Circuit Model (ECM), you can use it to create a lumped model for a single battery cell or a module using Battery Wizard Toolkit. You can connect several modules together to build a pack. In addition, you can use the Thermal Model Identification Toolkit to create a thermal reduced order model for a battery pack. More details can be found in the Battery learning room within Ansys Learning Hub.
