Is there a faster way to remove radius corners than manually clicking each one?
I'm trying to prepare a model for FEA.
  • The fastest way to select multiple similar items of any kind is by using the Power Selection function located in the Selection tab below the Structure Tree. This will allow you to select groups of items based on different criteria such as size, color, or type:
    PowerSelectpng
