Polymer material definition using tensile test data (linear part Hyperelastic material model)
Hello
I am trying to define a Polymer material based on tensile test data. my main issue is the polymer enters the plastic zone after 70% strain.
I am using this polymer in an application that works only in the elastic zone of the material (entering the plastic zone for my application means failure).
I used Yeoh 3rd order (hyperelastic model) to define only the elastic part of the curve ( less than 70% strain) and my simulation ( using static analysis in ansys work bench) works well, is this right? if not I would appreciate it if you suggest the right method for defining the material.
I checked the forum and I understood that Hyperelastic materials should not be used with plastic materials.
I uploaded the tensile test figure for the polymer.
Best Answers
  • A_zaghloulA_zaghloul Member
    Accepted Answer
    Hi bsista,
    Thank you for your answer.
    I would appreciate it if you suggest specific reference that I can use it to reference this part if available.
    The only thing that makes me confused I calculated the modulus of elasticity form the curve for 10 % strain, the value will be around 25 MPa ( calculated from the slope of the stress-strain curve), and I will assume the poison Poisson ratio=0.49 My question is when I used these values instead of the hyperelastic model the solution did not converge.
    and I got this error
    "internal solution magnitude limit was exceeded ansys workbench"
    shall I stick to the hyperelastic model?
    Accepted Answer
    Hi bsista,
    I think I fixed the problem by increasing the number of sub steps in my simulation.
    I would appreciate it if you suggest specific reference that I can use it to reference (the hyper elastic part) if available.
    Accepted Answer
    Hi bsista,
    Accepted Answer
    Hi bsista,
  • hi, is it okay to use ONLY uniaxial test data for curve fitting? I could get good fit with this curve, but getting different biaxial and shear data on using different models. How safe is it to use ONLY uniaxial test data? The curve I am interested is of 23 deg C, and shown part of it is all elastic. I wanted to Load till 66 Mpa. Kindly help..
