Сalculation of the bearing capacity of a pile for a pile field
Hello dear forum participants. I am very interested in help in solving such a non-standard problem:
Сalculation of the bearing capacity of a pile for a pile field (for example, 4 piles with a square arrangement) small for permafrost soil, taking into account the probability of its seasonal thawing (with the possibility of thermal stabilization of the near-pile zone).
The following pile parameters are known:
Diameter - 219 mm (wall thickness 11 mm)
Immersion depth in the ground - 25 m
Load on one pile up to 50 kN
Corrosion activity on carbon steel - moderately aggressive
On concrete structures - non-aggressive
Arrangement of piles in a square with a distance between them 3000 mm
The following soil parameters are known:
values ​​of natural moisture and density of wet soil 0.47 and 1.74 g / cm3
porosity coefficient - 1.288
specific adhesion value 9 kPa
angle of internal friction 5.7 °
Compression modulus 0.4 MPa
Guideline value of adhesion according to triaxial tests 14 kPa
Plasticity 0.21
Frozen ground temperature minus 0.1 minus 3 °С
Frozen soils are in a frozen state
The temperature of thawed soils reaches a maximum value of 0.5 °С
