Analysis system missing in toolbox (Ansys student 2020 R2)
I just downloaded Ansys student 2020 R2 and I am not able to find the analysis system in the toolbox. I went through the forum and tried a couple of things.
- View - Reset Workspace, View - Customize toolbox (didn't help)
- rename the v202 folder to anything else (didn't help)
- open up CMD Prompt, then issue the following command (this is for default installation path, if you've installed it in a non-default path, you have to change the path accordingly)
"C:Program FilesANSYS IncANSYS StudentShared FilesLicensingwinx64ansysli_util" -checkout aa_t_i
and I initially got a message saying:
INFO Demo license file C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\student.lic exists.
'INFO' is not recognized as an internal or external command,
operable program or batch file.
aa_t_i OUT
'aa_t_i' is not recognized as an internal or external command,
Resolved by Feature: id=183 feature=aa_t_i product=ANSYS Academic Teaching Introductory
'Resolved' is not recognized as an internal or external command,
After I allowed access to the license through the windows firewall, I got a message saying:
aa_t_i OUT
But even after trying this out, The analysis system is not appearing in the toolbox.
I request you to help me resolve this soon.
Thank you,
Prathiksha
Hi Prathiksha,
Check out the resolutions in
and
basically, check if you have the two environment variables set. If so, delete them.
Win
I am seeing the same problem as Prathiksha -- no analysis system in the toolbox with Workbench 2020 R2. I have followed the advice given with environment variables and opened up the firewall for license server.
Please advise how to fix.
@tsiriaks please advise how to fix
Please post the output of 'set' command (without quote) from CMD Prompt
set command output...
ALLUSERSPROFILE=C:\ProgramData
ANSYS202_DIR=D:\Program Files\ANSYS Inc\ANSYS Student\v202\ANSYS
ANSYSLI_ELASTIC=0
ANSYSLI_LCP=0
ANSYS_SYSDIR=winx64
APPDATA=C:\Users\George\AppData\Roaming
AWP_LOCALE202=en-us
AWP_ROOT202=D:\Program Files\ANSYS Inc\ANSYS Student\v202
CADOE_LIBDIR202=D:\Program Files\ANSYS Inc\ANSYS Student\v202\CommonFiles\Language\en-us
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=RUTHERFORD
ComSpec=C:\WINDOWS\system32\cmd.exe
DriverData=C:\Windows\System32\Drivers\DriverData
HOMEDRIVE=C:
HOMEPATH=\Users\George
LOCALAPPDATA=C:\Users\George\AppData\Local
LOGONSERVER=\\RUTHERFORD
LSTC_LICENSE=ANSYS
NUMBER_OF_PROCESSORS=4
OMP_NUM_THREADS=4
OneDrive=C:\Users\George\OneDrive
OS=Windows_NT
Path=C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\PuTTY\;C:\Users\George\AppData\Local\Microsoft\WindowsApps;
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 158 Stepping 9, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=9e09
PROG27B48B2C052=1
ProgramData=C:\ProgramData
PROMPT=$P$G
PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules
PUBLIC=C:\Users\Public
P_SCHEMA=D:\Program Files\ANSYS Inc\ANSYS Student\v202\AISOL\CADIntegration\Parasolid\PSchema
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\Users\George\AppData\Local\Temp
TMP=C:\Users\George\AppData\Local\Temp
TMPDIR=C:\Users\Public\Documents\Wondershare\CreatorTemp
USERDOMAIN=RUTHERFORD
USERDOMAIN_ROAMINGPROFILE=RUTHERFORD
USERNAME=George
USERPROFILE=C:\Users\George
windir=C:\WINDOWS
Interesting.
Try this. Make sure all ANSYS applications are closed, then rename
D:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\ansyslmd.ini
to anything else (e.g., ansyslmd.bak)
Then, open CMD Prompt and enter the following command
Does this help ?
If not, try the following commands
set ANSYSLI_ELASTIC=
set ANSYSLI_LCP=
set Path=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem
"D:\Program Files\ANSYS Inc\ANSYS Student\v202\Framework\bin\Win64\runwb2.exe"
Does this WB session work ?
Hello Tsiriaks
I tried both instructions. In both cases the results are the same....
Here are the environment variables after the second set of commands
ANSYS_SYSDIR=winx64
AWP_LOCALE202=en-us
HOMEDRIVE=C:
LSTC_LICENSE=ANSYS
OMP_NUM_THREADS=4
OS=Windows_NT
PROCESSOR_LEVEL=6
PROG27B48B2C052=1
PROMPT=$P$G
SESSIONNAME=Console
SystemDrive=C:
USERNAME=George
windir=C:\WINDOWS
Licenses seem to be installed ok....
Now I think this is not licensing issue anymore.
Check your D:\Program Files\ANSYS Inc\ANSYS Student\
to see if you have install.err file. If so, post the content here.
You can also try running
D:\Program Files\ANSYS Inc\ANSYS Student\v202\productconfig.exe
with 'run as administrator', then select Configure products and configure them all in the list.
Hello Tsiriaks
there is not "install.err" file. "Install.log" does not contain any error messages.
I ran thru all the functions in productconfig.exe but still cannot see CAD modules...the list of products to configure is empty. Screenshots are in reverse order below..
Wait, your 'Select the product(s) to configure' page is blank
Please post the top part of your install.log before it starts the extraction. If you did multiple installations, post the top part of each occasion.
Also, in Workbench -> Help -> About ANSYS Workbench , then post the screenshot of it here
Now, I think you probably have two locations of ANSYS 2020 R2 installed on the machine and your environment variables and shortcuts are pointing to the wrong one.
Hello Tsiriaks
you are right, I originally tried to install on C: but ran out of space so change to install on D:.
So i decided to go right back to the beginning an reinstall...
Results...
In short, no visible change. Not sure why this is so difficult.....HELP !!!
I attach relevant images. I tried running ANSLIC_ADMIN based on some old FAQ i found online and got an error message. Not sure if that helps.
Hello Tsiriaks....any thoughts on the above ?
Now, I see. You use the wrong package. I thought you also use the 'ANSYS Student' package when you first described the issue. It seems you just meant ANSYS Student version/license.
The 'AIM' package does allow you to open Workbench (because AIM is customized from Workbench) but this Workbench won't function on itself. If you use this package, you must use only the Discovery AIM.
Try the other package 'ANSYS Student', see if that makes a difference.
Hello Tsiriaks
this works, thank you !!
Actually the difference between the 3 student packages is not really clear. I understood AIM is a newer package with much faster simulation results, so that's why i chose that. Is it possible to upload CAD model and do fluid/thermal simulation in AIM, or should i stick with Ansys student ?
Best regards -- George
That's great ! Thanks for the update.
AIM is mostly for 'designer' to quickly view some simulation results per the design that you make. But if you want thorough calculations, you need to use the flagship solvers like Mechanical, Fluent, etc. , which are available in ANSYS Student installation package.
As for the question with CAD, I'd recommend to ask that on another section like
they would be able to provide a better response.
I have installed Ansys 2020 R2 and the analysis tool is missed up, I wrote the follwing command "set" s
C:\Users\Muhan>set
ANSYS202_DIR=D:\Ansys_Student_Program_R2\ANSYS Inc\ANSYS Student\v202\ANSYS
ANSYSLI_LCP=1
ANSYS_SYSDIR=winx64
ANSYS_SYSDIR32=win32
ANS_OLD_ATTACH=1
APPDATA=C:\Users\Muhan\AppData\Roaming
AWP_LOCALE202=en-us
AWP_ROOT202=D:\Ansys_Student_Program_R2\ANSYS Inc\ANSYS Student\v202
CADOE_LIBDIR202=D:\Ansys_Student_Program_R2\ANSYS Inc\ANSYS Student\v202\CommonFiles\Language\en-us
COMPUTERNAME=DESKTOP-KSDPGQ0
ComSpec=C:\Windows\system32\cmd.exe
GOOGLE_API_KEY=no
GOOGLE_DEFAULT_CLIENT_ID=no
GOOGLE_DEFAULT_CLIENT_SECRET=no
HOMEDRIVE=C:
HOMEPATH=\Users\Muhan
ICEMCFD_SYSDIR=win64_amd
LOCALAPPDATA=C:\Users\Muhan\AppData\Local
LOGONSERVER=\\DESKTOP-KSDPGQ0
LSTC_LICENSE=ANSYS
NUMBER_OF_PROCESSORS=8
OneDrive=D:\New folder\OneDrive - estudiant.upc.edu
OneDriveCommercial=D:\New folder\OneDrive - estudiant.upc.edu
OneDriveConsumer=C:\Users\Muhan\OneDrive
OS=Windows_NT
Path=C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files\MATLAB\R2020a\runtime\win64;C:\Program Files\MATLAB\R2020a\bin;C:\Program Files\Git\cmd;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\110\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\DTS\Binn\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;C:\Users\Muhan\anaconda3;C:\Users\Muhan\anaconda3\Library\mingw-w64\bin;C:\Users\Muhan\anaconda3\Library\usr\bin;C:\Users\Muhan\anaconda3\Library\bin;C:\Users\Muhan\anaconda3\Scripts;C:\Users\Muhan\AppData\Local\Microsoft\WindowsApps
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 142 Stepping 11, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=8e0b
PROMPT=$P$G
PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\Windows\system32\WindowsPowerShell\v1.0\Modules;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\PowerShell\Modules\
P_SCHEMA=D:\Ansys_Student_Program_R2\ANSYS Inc\ANSYS Student\v202\AISOL\CADIntegration\Parasolid\PSchema
SESSIONNAME=Console
SW_SIM_HYDRA=C:\Program Files\Common Files\SolidWorks Shared\Simulation Worker Agent\
SW_SIM_MPIT=INTELMPI
SW_SIM_TEMP=C:\ProgramData\SOLIDWORKS\SW_net_sim_temp\
SystemDrive=C:
SystemRoot=C:\Windows
TEMP=C:\Users\Muhan\AppData\Local\Temp
TMP=C:\Users\Muhan\AppData\Local\Temp
USERDOMAIN=DESKTOP-KSDPGQ0
USERDOMAIN_ROAMINGPROFILE=DESKTOP-KSDPGQ0
USERNAME=Muhan
USERPROFILE=C:\Users\Muhan
windir=C:\Windows
could you please help me to fix the problem ?
