LS DYNA Not solving 'error connecting to service '
i was simulating an explicit dynamics problem using ansysR19 and after solving it in workbench (which it completed) and exporting it as lsdyna input file (.k); when i am trying to run the lsdyna from the app launcher it displays this message (shown in the picture). Please help?
  • edited August 2020
    looks like Wish.exe isn't finding the proper intel mpi libraries or it could be a permissions issue also...very likely because Intel MPI isn't properly configured.
    I would recommend re-installing Intel MPI (w_mpi_p_2018.3.210.exe) for ANSYS Parallel Processing from as an administrator:
    C:\Program Files\ANSYS Inc\v195\prereq
    and caching the password using the following command:
    "%AWP_ROOT195%\commonfiles\MPI\Intel\2018.3.210\Windows\setimpipassword.bat"
    Try restarting your machine after this and see if it helps.
  • Hi !!
    I don't know if your problem is solved,.
    I solved the same problem.
    I attached a picture about how to set ansys mechanical launcher.
    It Works for me!
    Regards
