Change the legend in Mechanical APDL solution plot
I believe this is a trivial question, but I couldn't find a solution after quite some research.
I did a structural analysis in Mechanical APDL, and plotted the solution, which looks like this:
Now the problem is, that the constraints to keep the structure from moving, produce infinitesimal small areas with very high tensions. This leads to the legend to show a huge range of values.
I would like to define a range for the legend (in this case 1925 to 3500 or similar) to see small changes in tension throughout the structure.
Is it possible to change the values of the legend so that the colour range will be used for a smaller range of values?
Kind regards.
