How to model a repeating load?
in order to model a repeating pressure pulse load as defined in the attached article, I've simulated the attached project. The fact is that I can reach the desired results for the first two pulses, but for the third pulse I just get the exact same result as the 2nd pulse (Figure 13, as highlighted). How can I fix this problem?
Thanks in advance,
Elham
