DYNA CONTROL_REFINE_ALE
Hi guys,
I encountered a problem, while try to use CONTROL_REFINE_ALE. I try to simulate wind blow flat plate. Without CONTROL_REFINE_ALE, simulation works fine. After added this keyword, the simulation seems stuck in the pre-process. No warning or error message either. Don't know if you guys know how to fix this. Any advise will be welcome. Thanks a lot.
Problem solved, I should use higher version of LS-DYNA.
Great! Thanks for sharing!
