Unable to start the Meshing editor: Object reference not set to an instance of an object.
ArunSJTArunSJT Member
edited August 20 in Ansys Products
I'm trying to open Mesh Editor and ending up with the error. Unable to start the Meshing editor: Object reference not set to an instance of an object.
I tried reinstalling the software.
Turning off the Windows security.
Updating my NVIDIA graphics.
Nothing helps me.
Kindly do the needful.
Thankyou,
Arun
    Hi Arun,
    Are you connecting to VPN ?
    Also, what ANSYS version you are using ?
    Please provide the output of the following command
    set
    from CMD Prompt.
    Win
  • Hi Tsiriaks,
    Thank you for the reply.
    1. No, I'm not using VPN
    2. ANSYS version is 2020R2 (Student)
    Output of the command 'set' is
    OS=Windows_NT
    Path=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files\dotnet\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\170\Tools\Binn\;C:\Users\91893\AppData\Local\Microsoft\WindowsApps;;C:\Users\91893\AppData\Local\Programs\Microsoft VS Code\bin
    PROCESSOR_ARCHITECTURE=AMD64
    PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 126 Stepping 5, GenuineIntel
    PROCESSOR_LEVEL=6
    PROCESSOR_REVISION=7e05
    ProgramData=C:\ProgramData
    ProgramFiles=C:\Program Files
    ProgramFiles(x86)=C:\Program Files (x86)
    ProgramW6432=C:\Program Files
    PROMPT=$P$G
    PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\Windows\system32\WindowsPowerShell\v1.0\Modules
    PUBLIC=C:\Users\Public
    P_SCHEMA=C:\Program Files\ANSYS Inc\ANSYS Student\v202\AISOL\CADIntegration\Parasolid\PSchema
    SESSIONNAME=Console
    SystemDrive=C:
    SystemRoot=C:\Windows
    TEMP=C:\Users\91893\AppData\Local\Temp
    TMP=C:\Users\91893\AppData\Local\Temp
    USERDOMAIN=DESKTOP-ARUN
    USERDOMAIN_ROAMINGPROFILE=DESKTOP-ARUN
    USERNAME=91893
    USERPROFILE=C:\Users\91893
    windir=C:\Windows
    Kindly do the necessary.
    Regards
    Arun
    Hi Arun,
    Thank you for the info. Can you show the first half of the output of 'set' command as well ?
    Are you able to open Design Modeler or it has the same issue ?
    Is there an install.err file under C:\Program Files\ANSYS Inc\ANSYS Student\
    Please launch 'dxdiag' , then click the Display tab and post the screenshot of it here. If you have multiple monitors, post all Display tabs.
    Thank you,
    Win
  • Hi Tsiriaks,
    The full output of the set command.
    C:\Users\91893>set
    ALLUSERSPROFILE=C:\ProgramData
    ANSYS202_DIR=C:\Program Files\ANSYS Inc\ANSYS Student\v202\ANSYS
    ANSYS_SYSDIR=winx64
    ANS_OLD_ATTACH=1
    APPDATA=C:\Users\91893\AppData\Roaming
    AWP_LOCALE202=en-us
    AWP_ROOT202=C:\Program Files\ANSYS Inc\ANSYS Student\v202
    CADOE_LIBDIR202=C:\Program Files\ANSYS Inc\ANSYS Student\v202\CommonFiles\Language\en-us
    CommonProgramFiles=C:\Program Files\Common Files
    CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
    CommonProgramW6432=C:\Program Files\Common Files
    COMPUTERNAME=DESKTOP-ARUN
    ComSpec=C:\Windows\system32\cmd.exe
    DriverData=C:\Windows\System32\Drivers\DriverData
    HOMEDRIVE=C:
    HOMEPATH=\Users\91893
    ICEMCFD_SYSDIR=win64_amd
    LOCALAPPDATA=C:\Users\91893\AppData\Local
    LOGONSERVER=\\DESKTOP-ARUN
    LSTC_LICENSE=ANSYS
    NUMBER_OF_PROCESSORS=8
    OneDrive=C:\Users\91893\OneDrive
    OneDriveConsumer=C:\Users\91893\OneDrive
    OS=Windows_NT
    PROCESSOR_LEVEL=6
    PROMPT=$P$G
    SESSIONNAME=Console
    SystemDrive=C:
    USERNAME=91893
    windir=C:\Windows
    I can use Design Modeler
    No error files
    'dxdiag' screenshot
    Hi Arun,
    Thanks for the info.
    What if you right click on the desktop then launch Nvidia Control Panel >> Manage 3D settings >> set Preferred graphics processor to be "High-performance NVIDIA processor”
    You can also try another setting from Intel graphics control panel. Make sure the power option is set to maximum performance. You can play around with the options under the '3D' setting too.
    Win
  • Hi Tsiriaks,
    I tried in High-performance NVIDIA processor.
    It is not working.
    Please suggest me some other options.
    Regards
    Arun
  • This was happened after I tried Fluent with Meshing option in Work bench.
    I can use all other tools except meshing.
    Regards
    Arun
    Hi Arun,
    Ah, I didn't realize this is Fluent meshing. I thought it's ANSYS meshing.
    In that case, if you try stand-alone Fluent with meshing mode selected, does this work ?
    Win
    Hi Arun,
    That's actually ANSYS meshing.
    What if you do this
    Under the Component Systems, add the Mesh component. Then draw something in Geometry cell and try opening the Mesh cell
    Do you get the same issue ?
    If so, try the followings
    1. reinstalling prerequisites (you need admin rights for this) by going to folder (default) C:\Program Files\ANSYS Inc\v###\prereq , and manually run all the installers here one-by-one. Make sure they are all successful. You can skip the opencl and MPI related ones. You may need to reboot after this.
    2. Open elevated CMD Prompt (right click on CMD and 'run as administrator' ), then enter the following commands
    regsvr32.exe ole32.dll
    regsvr32.exe atl.dll
    regsvr32.exe oleaut32.dll
    regsvr32.exe scrrun.dll
    regsvr32.exe jscript.dll
    regsvr32.exe vbscript.dll
    Win
