Ansys Solcing Methods
Mac123Mac123 Member
edited August 23 in Structural Mechanics
Hey,
So I have been using Ansys for a while and I feel I am able to understand and use It fluently.
But I always have a doubt regarding discretization and Interpolation .
I would like to clear that off before I start working on something big.
Lets Say Structures for example - Whats ansys does is :
We choose the mathematical model and it's respective governing equations
Then we apply the weighted function for piece wise polynomial approximation- to make it simple
(Differential equations to linear)
Then define a equation for a node- Which is discretization.
Then we obtain the equations for the other nodes using interpolation.
Then set the boundary conditions
After which we obtain a system of linear equations and solve them.
After which any other variable can be found .
If non-linear
We apply guess values , imbalance reduction and so on.
I know this is a bit lengthy ,
But please correct me , please ,
If I made a mistake while stating the solving steps of ANSYS.
Thank You Very Much !
  • Mac123Mac123 Member
    edited August 29
    Thanks Mr.Peter
    So we obtain the nodal equations using interpolation.
    Use these set of equations and change it to a matrix.
    Then after solving it.
    We obtain the nodal values throughout the surface or 3D model.
    And once we know those values , we can compute any variable and interpolate to find it at any location right ?
    edited August 30
    The nodes are connected to elements. Elements define stiffness between nodes. The element stiffness values are assembled into a matrix [K] that has rows and columns. The unknown nodal displacements are assembled into a vector {x} and the applied forces are assembled into another vector {F}. The matrix equation is [K]{x} = {F}.
    Solving the matrix calculates a solution for each unknown value of x. Once the post-processor knows the values of x at all the nodes, the element shape function allows it to interpolate the displacement of any point inside the element.
    x means a displacement Degree of Freedom (DOF). A node might have 3 DOF, in the X, Y and Z directions so there are three cells in the {x} vector for each node.
    Thank you ,
    I get it now
    Basically the {x} matrix consists of all the nodal displacement equations .
    Upon solving that matrix , we obtain those nodal values
    So it allows us to calculate any variable such as stress , strain deformations , etc
    edited August 31
    Exactly. Some textbooks call the displacement vector {U} to avoid using x which is a component on one nodal displacement.
