How do I change the working directory on command line
shojishoji Member
I want to change the working directory without using fluent launcher.
Are there any commands to change working directory following this command ?
Any advice would be appreciate.
Thanks.
  • shojishoji Member
    I know the way to change directory using chdir command in fluent console, but I want to select working directory before fluent app start-up in command line.
    Is this related to Ansys product?
  • shojishoji Member
    edited August 24
    Yes. this is about ansys fluent.
    I know I can change working directory on the launcher, but now I want to change it on windows command line.
    What do you want do? To change the working directory while launching Fluent? All available command flags are listed when you launch with -h.
  • shojishoji Member
    edited August 25
    Yes.
    I want to change the working directory while launching Fluent. Are there any options to change it on command line?
  • shojishoji Member
    I want to use fluent with matlab in ass mode. But once I start-up fluent launcher, I can't operate it from matlab. So I need to launch fluent directly from matlab and without launcher.
    When I start-up fluent using below command, working directory is set to same as fluent directory( C:\Program Files\ANSYS Inc\v172\fluent\ntbin\win64).
    But I want to set working directory as the other directory(C:\Users\shoji\Desktop\matlab).
    Therefore, I would like to know how to change the working directory in windows command line.
    When I tried to change working directory after start-up Fluent, matlab and fluent didn't connected.
    Thanks.
