Modeling fluid resistivity
Hi All,
I would like to model the resistivity of a fluid in a container. The premise is that a resistive fluid is between two conductive nodes, one being the voltage source and the other ground. I would like to know the value of resistance of the fluid, so it does not fall bellow a certain value, and design the container appropriately if necessary. The container would also be of an irregular form.
How could I go about doing this.
Kind regards.
It is possible to model it in Ansys Fluent using the Potential model. However, I'd recommend that you use Ansys Maxwell or Ansys Electric to model this.
Thanks.
