Error in ANSYS Workbench Student Version
Recently i have installed ANSYS Student software (ANSYS 2020R2) in my laptop.I am able to create the geometry but when i am trying to attach geometry into mesh it is showing the following error.
AnsysWBU.exe encountered a problem.A diagnostic file has been written:C:\Users\Ramana\AppData\local\Temp\AnsysWBDumpFile.dmp
My laptop has NVDIA Getforce graphics card of 6GB with dedicated Video memory(VRAM) of 2GB.
Please help me to fix this problem.
Thank you
Hi @Shyamprasad ,
The model might have corruoted. Can you try creating a new project?
Ashish Khemka
yes, i have created a new model.But still i am getting the same error.
Can you do a quick test with the following?
@subhamdas
I have tried using a simple geometry...but still i am getting the same error.
Did you try installing the software on a separate system?
You can also try updating your Nvidia driver (please go to Nvidia website, do not use Windows Device Manager)
Then, make sure that your machine uses Nvidia card. Right click on the desktop then launch Nvidia Control Panel >> Manage 3D settings >> set Preferred graphics processor to be "High-performance NVIDIA processor.
Thank you for your reply.
I followed your instructions.But still i am getting the same error.
Close all ANSYS applications, then open elevated CMD Prompt (right click on CMD and 'run as administrator') and enter the following commands
regsvr32.exe ole32.dll
regsvr32.exe atl.dll
regsvr32.exe oleaut32.dll
regsvr32.exe scrrun.dll
regsvr32.exe jscript.dll
regsvr32.exe vbscript.dll
make sure all are successful. If not, let us know.
If that doesn't help, try the following commands
set PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
"%awp_root202%\Framework\bin\Win64\runwb2.exe"
and see if this particular Workbench session work
If that doesn't work either, open up Products & CAD Configurations with 'run as administrator' >> "Configure Products & CADs" >> select all options
If issue persists, open CMD Prompt and enter the following command
set
then post the output of it here.
Also, open up Windows Event Viewer -> Custom Views -> Administrative Events
Is there any Error logged when this issue occurred ?
I am getting the error 'mesh generation couldn't complete due to poor quality' in ANSYS 19.1 version...
I have tried with different mesh settings and different geometries. But still i am getting the same error.
Please help me to solve this issue.
Thank you
