Error with SPICE model importing in Ansys Simplorer
samosmsamosm Member
edited August 28 in Electronics
Dear all,
I have trouble importing a LTSpice model into Anysis Simplorer.
The model i am trying to import is a model of MOSFET from ON Semiconductors (https://www.onsemi.com/support/design-resources/models?rpn=FDBL86361_F085).
I import the model as follows:
in Simplorer by clicking Tools > Project tools > Import simplorer models and when the dialog to select the file opens i open the .txt file that came when i downloaded the simulation model from ON Semi.
After i click Ok to import the model i get an error in Simplorer stating the following:
20200718_Synchronous_Buck (C:/Users/Samo/Documents/Studij/20191106_Raziskovalno_delo/1. Projekti/4. Synchronous Buck/)
 [warning] Unable to find any SPICE models to import from C:/Users/Samo/Documents/Studij/20191106_Raziskovalno_delo/1. Projekti/4. Synchronous Buck/1. Components/3. MOSFET/2. ON Semi, FDBL86361_F085/2. Simulation models/LTSpice/mv7n_80v_std_rev3.2_ltspice.txt (10:00:15 AM Aug 28, 2020)
How can i work around this error and get the model imported?
Thank you for the help.
Best regards,
Samo
