Unable to contact license server machine
When running the ANSLIC_ADMIN utility I get the following error. I am trying to connect to a 5 seat ansys license from my laptop that is hosted on a desktop.
[Detecting lmgrd processes...]
Error getting status: License server machine is down or not responding. (-96,7:11001 "WinSock: Host not found (HOST_NOT_FOUND)")
The diagnostics for my laptop are attached. This is for 2020 R2.
The license manager is up and running on the host computer. I have added the required Ansys firewall exceptions for both computers. I can ping the IP of the desktop from my laptop in the command prompt.
  • tsiriaks,
    Thank you for the quick reply. I should have been more clear. This is for the ANSYS CFD package.
    The issue has been resolved. I could find the host by IP but not by name. When I put the IP in the ANSLIC_ADMIN utility instead of the name I could find it but that did not match the license file I was given on the SERVER line like you mentioned.
    I fixed this by matching the host name to the host IP on the "hosts" file on my computer. Instructions are given in the following link. https://www.howtogeek.com/howto/27350/beginner-geek-how-to-edit-your-hosts-file/
    Cory
    Hi Cory,
    That's great ! Thank you for the update. Glad the issue is fixed.
    You are correct. My info won't 100% apply to Mechanical/Fluids. In this case, you don't need the SERVER line on the license file to match what you specify on the client side.
    Cheers,
    Win
