Workstation configuration for Fluent
yelyaayelyaa Member
edited September 1 in Ansys Products
Dear Ansys community,
For my thesis, my lab has given me a budget to set up a workstation for my work (and for them for the future)
The budget allows me to go for a 14-core CPU (we can afford a ~1000-1300 $ CPU), and I am a bit lost in the choice to be honest.
For now I foresee an Intel Xeon w-2275, but I was wondering if going for a Xeon, instead of an i9 for example, or maybe a similar performance AMD is worth it.
The only advantage I see in the Xeon for the moment is the ECC option, does it really make a difference ?
Thank you very much for your help
  • Moving this to the Installation thread for better alignment.
    Please have a look at the following links.
    Thanks.
     Here is recommended hardware (of course, you do not need to match all these specs)
    Intel® Xeon Core series 62xx also known as “Cascade Lake” Processors
    • Turn off Hyper-threading
    • Leave Turbo boost on
    Memory (Fastest memory, so DDR-4 2933 MHz)
    • To operate at maximum speed all memory channels in both processors should be populated with equal amounts
    of memory. Minimum 192 GB RAM per machine to meet this requirement.
    Interconnect (Server/Cluster solution ONLY)
    Omni-Path, EDR, QDR or FDR IB interconnect if you will be running on 2 or more nodes in parallel (on a cluster, Minimum
    10 G network.
    Hard Drives
    SSD (NVMe, M2 interface) drives.
    Graphics (Rendering)
    Nvidia Quadro NVIDIA® Quadro® P4000, NVIDIA® Quadro RTX™ 4000
    NOTE: For rendering/display – Ansys requires OpenGL and the workflow that is recommended is that you do all
    pre/post processing on a workstation and not on a server unless it is a graphics server. A high-end OpenGL graphics
    card and recent drivers are required.
    GPU (CFX does not support GPU)
    AVX2 (Fluent Only)
    • Supported ONLY for Fluent 18.2 and higher using this flag in your startup script: -platform=Inte
