VCCT delamination using plane182 with plane stress with thickness
Hello Team,
I faced an issue while validating the DCB test for delamination using Ansys plane 182 plane stress option using VCCT
-->The critical load as predicted by ansys doesn't seem to match with the expected values: It under-predicts the critical load for delamination.
-->Also, the initial slope of the force-deflection before the failure initiates also appears to be not matching.
I tried refining the mesh and using higher order but the issue still persists.
I have attached the input file: dcb.dat to reproduce this issue. Also attached is the image of the various simulated results.
The parameters of DCB are:
L=200           !* length
dh=40            !* total thickness
a0=100 ! pre-crack length
nel=200           !* no.elements along length
neh=40            !* no.elements along thick
emod=2.0e+05 ! E
thick=10 ! width
g1c=0.9628         !* critical energy-release rate
pratio=0.3 ! *Proisson ratio
Please let me know your comments on observed results and suggestions. also, may i know if there is any validation problem to verify using plane stress option.
  • Where do the expected results come from?
    Your plot legend says ref and in house code. What are those?
  • Hello,
    Ref is taken from the paper: Wei-Jian Li, Qi-Zhi Zhu, Tao Ni,
    A local strain-based implementation strategy for the extended peridynamic model with bond rotation, Computer Methods in Applied Mechanics and Engineering,
    Volume 358, 2020, 112625,ISSN 0045-7825, https://doi.org/10.1016/j.cma.2019.112625.(http://www.sciencedirect.com/science/article/pii/S0045782519305079)
    In house codes are ones we are trying to reproduce and match with Ansys results. i'm unable to attach the input file, so copied those contents here:
    finish
    /clear,nostart
    /prep7
    dis1=0.35 ! >=0.397435 0.4 (1125.94)
    dis2=1.0
    n1=1000
    n2=1000
    n3=10
    dl=200           !* length
    a0=100
    toler=0.1e-5
    emod=2.0e+05
    thick=10
    g2c=0.0
    g3c=0.0
    EI=emod*0.5*dh*0.5*dh*0.5*dh*thick/12
    deno=emod*0.5*dh*0.5*dh*0.5*dh
    Pc=sqrt(g1c*deno/3.0)*(thick/(2*a0))
    Uc=2*sqrt(g1c/(3*deno))*a0*a0
    pratio=0.4
    et,1,182          !* 2d 4-node structural solid element
    !keyopt,1,1,2        !* enhance strain formulation
    keyopt,1,3,3        !* plane strain
    et,2,182
    !keyopt,2,1,2
    keyopt,2,3,3
    et,3,202          !* 2d 4-node cohesive zone element
    !keyopt,3,2,2       !* element free option
    keyopt,3,3,3        !* plane strain
    R,1,thick
    mp,ex,1,emod
    mp,prxy,1,pratio
    tb,cgcr,1,,3,linear    !* linear fracture criterion
    tbdata,1,g1c,g2c,g3c
    ! fe model
    rectng,0,dl,0,dh/2      !* define areas
    rectng,0,dl,0,-dh/2
    lsel,s,line,,2,8,2     !* define line division
    lesize,all,dh/neh
    lsel,inve
    lesize,all, , ,nel
    allsel,all
    type,1           !* mesh area 2
    mat,1
    local,11,0,0,0,0
    esys,11
    amesh,2
    csys,0
    type,2           !* mesh area 1
    esys,11
    amesh,1
    seltol,1e-06
    csys,0
    nsel,s,loc,x,a0-toler,dl
    nummrg,nodes
    esln
    type,3
    mat,5
    czmesh,,,1,y,0,      !* generate interface elements
    allsel,all
    nsel,s,loc,x,dl      !* apply constraints
    d,all,all
    nsel,all
    esel,s,ename,,202     !* select interface element to
    cm,cpath,elem       !* define crack-growth path
    nsle
    nsel,s,loc,x,a0
    nsel,r,loc,y,0
    esln
    cm,crack1,node      !* define crack-tip node component
    allsel
    finish
    /solu
    resc,,none
    esel,s,type,,2
    nsle,s
    nsel,r,loc,x
    nsel,r,loc,y,dh/2    !* apply displacement loading on top
    d,all,uy, dis1
    nsel,all
    esel,all
    esel,s,type,,1
    nsle,s
    nsel,r,loc,x
    nsel,r,loc,y,-dh/2     !* apply displacement loading on bottom
    d,all,uy,-dis1
    nsel,all
    esel,all
    autots,on
    nsubs,4,4,4
    time,1
    cint,new,1      !* crack id
    cint,type,vcct    !* vcct calculation
    cint,ctnc,crack1   !* crack-tip node component
    cint,norm,0,2
    ! crack-growth simulation set
    cgrow,new,1     !* crack-growth set
    cgrow,cid,1     !* cint id for vcct calculation
    cgrow,cpath,cpath  !* crack path
    cgrow,fcop,mtab,1  !* fracture criterion
    CGROW,DTIME,2.0e-3
    CGROW,DTMIN,2.0e-3
    CGROW,DTMAX,2.0e-3
    cgrow,fcra,1.02
    allsel,all
    outres,all,all
    solve
    esel,s,type,,2
    nsle,s
    nsel,r,loc,x
    d,all,uy, dis2
    nsel,all
    esel,all
    esel,s,type,,1
    nsle,s
    nsel,r,loc,x
    d,all,uy,-dis2
    nsel,all
    esel,all
    time,2
    nsub,n1,n2,n3
    solve
    finish
    /post1
    set,list
    *GET,nmaxset, ACTIVE, 0, SET, NSET
    *dim,imp_vol,,nmaxset,4,1
    /com, *********************************
    /com, Reference results:
    /com, A local strain-based implementation strategy for the extended
    /com, peridynamic model with bond rotation Comput. Methods Appl. Mech. Eng., 358 (2020), p. 112625
    imp_vol(1,3,1)=0
    imp_vol(1,4,1)=0
    imp_vol(2,3,1)=0.056544503
    imp_vol(2,4,1)=144
    imp_vol(3,3,1)=0.136125654
    imp_vol(3,4,1)=350.7692308
    imp_vol(4,3,1)=0.184293194
    imp_vol(4,4,1)=474.4615385
    imp_vol(5,3,1)=0.262827225
    imp_vol(5,4,1)=679.3846154
    imp_vol(6,3,1)=0.339267016
    imp_vol(6,4,1)=876.9230769
    imp_vol(7,3,1)=0.396858639
    imp_vol(7,4,1)=1026.461538
    imp_vol(8,3,1)=0.436649215
    imp_vol(8,4,1)=1133.538462
    imp_vol(9,3,1)=0.49947644
    imp_vol(9,4,1)=1028.307692
    imp_vol(10,3,1)=0.62513089
    imp_vol(10,4,1)= 919.3846154
    imp_vol(11,3,1)=0.753926702
    imp_vol(11,4,1)= 838.1538462
    imp_vol(12,3,1)=0.823036649
    imp_vol(12,4,1)= 803.0769231
    imp_vol(13,3,1)=0.882722513
    imp_vol(13,4,1)=773.5384615
    imp_vol(14,3,1)=0.956020942
    imp_vol(14,4,1)= 744
    imp_vol(15,3,1)=1.02408377
    imp_vol(15,4,1)= 721.8461538
    *cfopen,dcb_disp_force-ref,dat
    *vwrite,imp_vol(1,3,1), imp_vol(1,4,1)
    (1x,2G20.8)
    *cfclose
    fini
    /post26
    nsel,s,loc,y,dh/2
    nsel,r,loc,x,0
    *get,ntop,node,0,num,max
    nsel,all
    nsol,2,ntop,u,y,uy
    rforce,3,ntop,f,y,fy
    prod,5,2, , ,dis_tip, , ,1.0
    prod,6,3, , ,rf   , , ,1.0
    xvar,5
    /title,, dcb: reaction at top node verses prescribed displacement
    /axlab,x,disp Uy (mm)
    /axlab,y,reaction force Fy (N)
    plvar,6
    /com, export data to array parameters
    vget,imp_vol(1,1,1),5
    vget,imp_vol(1,2,1),6
    *cfopen,dcb_disp_force,dat
    *vwrite,imp_vol(1,1,1), imp_vol(1,2,1)
    (1x,4G20.8)
    *cfclose
    finish
