Icepak solver not running
Hello , Vikram here, I am using a research Mechanical and CFD license and trying to run an Icepak model.
Im trying to run a simple model , where the gpu chips produce heat.
I have used Cut-cell meshing with medium resolution mesh.
Problem setup :- buoyancy driven ,steady state, ignore radiation, boussinesq approx.
After I click on run calculation, The log is stuck here and the graphs do not appear.
It is not a license issue as Icepak is included in the Research mechanical CFD license.
But in the license manager application, license denials tab
Denials increase every time I run my model.
Thank you!
  • Vikram_AtreyaVikram_Atreya Member
    edited September 11
    Yes the model did run in fluent when i imported it with case file. Thank you!
