Ansys Linux issues
vinay91vinay91 Member
We have an academic license that runs on a cluster. Unfortunately, HFSS on the cluster does not render well over a X11 connection - at this point, I am not sure if that is a known HFSS issue or if it is specific to the hardware and networking parameters between the cluster and client (me). As of now, the only work around seems to be to use native HFSS (on client Windows) to draw and prepare for processing, then run a job on the cluster, and then again download the files to view the results natively.
When I say it does not render well, I mean that the screen blacks out when the cursor moves over the drawing area, or when a marker is added to any graph etc.
Anyone with similar issues? Any suggestions?
