Ansys Maxwell error 3221227010
Good evening, when I try to install the electromagnetic suite it shows these error at the end of the proces. Which can be the cause? I'm using an accademic license from home through my university VPN. Thanks in advance.
Mario
«1
    Hello Mario,
    This may be due to a Windows Update, patch KB4571756. We have had reports from several customers of this issue today. The suggestion at this time is to back-out the Windows Update KB4571756.
  • I did not update windows to that patch, I'm still on the previous one.
    Mario,
    Is it possible Updates were automatically installed? Please try these steps to verify.
    To uninstall the Windows update:
    1.           Select the start button or Windows Desktop Search and type update history and select View your Update history.
    2.           On the Settings/View update history dialog window, Select Uninstall Updates.
    3.           On the Installed Updates dialog window, find and select KB4571756, and then click the Uninstall button.
    4.           Restart your Windows device.
  • Same problem. Uninstalling KB4571756 and restarting windows fixed it.
    Freaking windows :)
  • I also faced same issue could you inform on this forum whenever windows patch the issue so that i can get the latest windows updates .
    Thank You
    A recent Windows update, Microsoft update KB4571756, results in one of the Windows functions (DescribePixelFormat) crashing on startup.
    For versions 2018.0 and newer, please try setting the environment variable ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL=1 to get around the problem.
    For guidance on creating an Environment Variable please refer to this link. You need to create a NEW Variable.
    https://www.computerhope.com/issues/ch000549.htm
    New Variable Name: ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL
    New Variable Value: 1
  • youssefaly97youssefaly97 Member
    edited September 2020
    I am facing the same issue, however adding this ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL=1 solves part of the problem, it gets SIwave to open the initializing/loading Window instead of just crashing without doing anything. I can confirm that by setting the value to 0 and trying again.
    Uninstalling KB4571756 gives the same results as ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL=1.
    @youssefaly97 - What is the issue you are encountering after setting the variable? Please provide details.
  • This only happens with SIwave, the rest of the suite open just fine.
    SIwave displays the initializing/loading window/screen for a few seconds, then a standard window opens that is just small enough for the close, maximize & minimize buttons. After a few seconds, both disappear and SIwave is no longer visible in the Task Manager.
    If the variable value is set to 0, or if I uninstall KB4571756, SIwave does not open any windows and is only visible in the Task Manager for a few seconds before it disappears.
    Currently running Windows 10 2004 with all updates installed.
    I have attached a screenshot for clarity.
  • I remembered something that hopefully can be useful solving this.
    When the update first came out SIwave would crash instantly. I tried to reinstall Ansys Electromagnetic Suite again but then it would come to the final part of the installation and would show a window called "Machine Configuration Failed". It gives an error code 3221227010 in the binary registration section next to reg_ansysedt.exe and reg_siwave.exe.
    Again, I have attached a screenshot for clarity.
  • Hi @mmadore ,
    You said that this environment variable fix should solve the problem for versions 2018+ -- is there by any chance a fix in the works for version 2015 as well? Unfortunately, setting the environment variable did not help in my case with Ansys 2015. I had to uninstall KB4571756 in order to get it working again.
    All the best,
    Ann Yanich
    Version 2015 is no longer officially supported. The only option would be uninstalling the update.
  • timlinNLtimlinNL Breda, NetherlandsMember
    For those who has tried the above but no luck yet, please try the followings:
    Open up Command Prompt -> Run as Administrator
    Send two commands to set the environment variables
    setx ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL 1
    setx ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL 1 /m
    This should work.
    Tim
  • I also had the same problem. I uninstalled the KB4571756 update and it worked. But when I turned the computer off and on again, the same problem happened again. What could be the reason?
    Could you help?
    @edaakar Did you set the environment variable as suggested above? Your system is probably reinstalling the update KB4571756 automatically, which is why it happens again after reboot.
    Matt
  • yes I have set it as examining the environment variable. But it didn't work.
    Please run the "set" command from a Windows command prompt and send the full output. Omit the "" from the command.
    Matt
    You may try uninstalling update KB4571756.
    Additionally, you may be able to run the following from an elevated CMD to uninstall the update:
      wusa /uninstall /KB:4571756 /quiet /promptrestart
  • i removed this update. It does not appear in updates. What can I do?
    @mmadore
