Fluent 2020 R1 will not see my university License via VPN
DaliaDalia Member
edited September 10 in Ansys Products
Hi All
I have recently installed Ansys 2020 R1 , via my university , I was given the port number and the flexIm and the hostname IP. I have made sure VPN is on while installing and while changing the license information or running Ansys
The license shows as in figures below
however when I try to open Fluent with a large mesh file, it gives me a message that this is an academic license
I installed and reinstalled a number of times, disabled all the firewalls and antivirus software.
I am not sure where the problem is
can someone help please ?
thanks
Dalia
    Hi Dalia,
    All of these are academic licenses. It's a matter of what kind of academic license you are using.
    The aa_r_me is ANSYS Academic Research Mechanical
    The aa_r_hpc is ANSYS Academic Research HPC
    If you want to use Fluent, you will need aa_r or aa_r_cfd licenses for Academic Research.
    Win
  • Hi Win
    Thank you for your reply.
    I managed to install Ansys again in campus without VPN.
    Fluent will now open and load the mesh only if I open it outside workbench, however it won't launch or load the file if it opens from workbench.
    I think the firewall might be blocking the access to license , what do you think I can try ?
    Dalia
    Hi Dalia,
    This is not a licensing issue now.
    Please post the screenshot of the issue or where it's stuck.
    From Workbench, does it launch the Fluent Launcher before you launch Fluent ?
    Win
