Fluent error pow2o3f on startup permanent fix?
nstrattoncsunstrattoncsu Member
edited September 11 in Ansys Products
"The procedure entry point pow203f could not be located in dynamic link library (path to fl2010.exe)"
So we have this error on start up. I've already read the forum posts on renaming the libmmd.dll to libmmd1.dll. This fixes the error, but only temporarily. Almost every week I have to rename the file to get Fluent working again. Are there any permanent fixes to this?
    If those 2 dll's keep showing up on your Windows system file, you will have to find which software places them there because this should not be a directory where software put things/libraries in.
    Once you are able to identify the culprit, please contact its vendor to see if there is anyway to put their libraries elsewhere, e.g., in their installation directory, etc.
