ERROR : [reg ansysedt exe] AnsysEM19.2
any help please !
Best Answers
mmadore Ansys Employee Posts: 717
Please try setting the environment variable ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL=1 to get around the problem.
Matt
You don't add it to the Path variable. You click "New" to create a new variable. The variable name will be ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL and the Value will be 1.
Matt
thank you for reply .
Where is it the variable "" ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL=1 ""
You need to set a new variable as detailed in this link.
https://www.computerhope.com/issues/ch000549.htm
I did it .
but not yet! the problem is still .
Could you help me with this? Thank you very much.
A window pops and says,
Failed to check out license 'hfss_desktop'.
Cannot connect to license server (FLEXlm Error -15)
Failed to check out license 'designer_desktop'.
Failed to check out license 'q3d_desktop'.
Failed to check out license 'maxwell_desktop'.
Failed to check out license 'simplorer_desktop'.
Failed to check out license 'electronics_desktop'.
it resolved
thanks
I was facing same problem. Followed the recommended steps and it resolved. Thank you So much Sir.
Hi mmadore ,
I am also getting same error.. while running my ANSYS app. I have made the changes as said here to make...
Please help
Error are as here:
Invalid license file syntax (FLEXlm Error -2)
@Lax can you please share a copy of your license file? This error is unrelated to the previous comments in this thread. This message is telling me the license is invalid.
Matt
Hi Matt,
I am facing similar issue. Despite adding the system variable I see the reg_ansysedt.exe Error
Abhi
@abhishek120 Can you open a Windows command prompt and run the command "set" without the quotes and share the full output?
Matt
Thanks, it worked after I restored my PC without the updates.
