See input and output parameters when using Mechanical APDL system and want to do DX study
djandricdjandric Member Posts: 16
We can define parameters in the MAPDL script and read the script in the MAPDL system. To see the parameters one would need to go to View>Outline on the project page. You should see "Process name.txt", table with the parameters should show up and you can define inputs and outputs.
