Multilayer metal deposition
Hi, i am trying to simulate multilayer metal deposition using 'element birth and death' technique.
I have glued the three volumes ie substrate, layer1,layer2 as shown in figure. Then, i am trying to kill the layer2 to simulate the deposition of layer1. At last, i will activate the layer2 and apply the load on the layer2.
Am i thinking in the right direction?
There are 43 loadsteps in each layer so i am using do loop but, i am getting following error,
Where do i place 'ekill' command in my code??
i am attaching the snapshot of the APDL script after meshing.
This error is coming because LSSOLVE/LSWRITE cannot be used with the birth-death option. Please refer to the documentation: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v193/ans_cmd/Hlp_C_LSWRITE.html?q=lswrite
You might need to use Solve command instead of LSSOLVE to run the model.
