Streamlines in EnSight using MRI data
I am using EnSight to post-process phase contrast MRI data of flow through arteries. I am able to compute the flow rate accurately in each branch using cut planes and obtain mass conservation. However, I am unable to generate streamlines from the main artery through the branches, since the streamlines stop prematurely after a short distance. Increasing the 'Total time limit' does not improve the results. Please see the images below.
Can anyone help with this please.
Thank you,
Gavin
  • KremellaKremella Posts: 2,497Admin
    edited August 2018
    Hi Gavin,
    Couple of quick questions:
    • Do you have more than one fluid cell-zones in your model?
    • Since this is a transient simulation, I am assuming that you are running a particle tracking model? Did you make sure to write the data is written for all time-steps? You should be able to check this from your folder where you are reading your ensight files from.
    Best,
  • MingMing Posts: 4Member
    edited February 2019
    I'm also using Ensight to post-process MRI data, and I need to import 4D flow MRI data which is in DICOM format into Ensight. However, I have no idea about this.
    Would you mind sharing that how to get the flow data from MRI?
    Ming
  • RobRob UKPosts: 8,966Forum Coordinator
    I'll lock this as you've reposted (new threads are always better).
