Material selection bug (Workbench 2020 R1)
Hi everyone,
I work on an structural-mechanical analysis in Ansys workbench 2020 R1. I define my structural steel, create my model, calculate and so on. Works all fine. When I change my geometry (e.g. create one more beam) and update it in mechanical, I have to select again my material. But there is no material displayed in the drop-down list (see picture).
My only solution is to reset the mechanical data. But it annoys, because I have to set the settings for the mesh, boundary conditions and solution settings new... The material can then be assigned again.
Is there someone with the same problem? Could it be a software bug (I think it is the latest version)?
Thanks and greetings,
Eppitnax
