Output complex eigenvectors
Hello
I'm doing a modal analysis and want to plot the strukture with the mode in matlab. Therefor I am exporting all my node connections and put them in a scatterplot in matlab. All fine.
Now I need the X,Y and Z values for the moving of the node connections for every mode. I tried with simply exporting the result of each deformation, which gave me only the absolute maximum for every connection.
I then found a command to use in my solution but it won't work. I always get the error that N is undefined. The code is...
rsys,solu
 nall
 /output, ev_real, eig
  *do, i, 1, N
       set,, i
       /page,,, 10000000
       prdisp
  *enddo
 /output, term
 /output, ev_imag, eig
  *do, i, 1, N
       set,,i,, 1
       /page,,, 10000000
       prdisp
  *enddo
 /output, term
finish
I put this in a command in the solution tree in workbench. If I change N to any value, workbench will stop at 10% processing.
Any one got an idea how to get the complex eigenvector in any way?
