Forced convection
HK2020HK2020 Member
edited September 18 in Fluids
I simulate the heat loss by forced convection and heat conduction from a heat storage tank with insulation in an air flow.
The problem is that I have no convection in the results. I had to create the contact surfaces manually, otherwise the error of overlapping contact surfaces occurs.
I suspect the error from this, but I do not know exactly. What can it result from? I would be very grateful for a solution suggestion.
