Error with installation and VPN licensing
Hey,
I tried to install the Teaching- license of our university („aa_t_a“). I first installed ANSYS 2020 R1 (3 ISO images) and after that the license manager. During both installations I got errors that should be stated in the log files. I shut down my anti-virus software and my firewall and was connected via VPN.
The then opened license manager "is stopped".
The error files:
___________________________________________________________
install.err
ANSYS installation: So Sep 20 00:01:58 2020
Revision: 2020 R1
  ###### Error #######
  Error extracting D:\license\WINX64.7z:
  '"C:\Users\sstap\AppData\Local\Temp\ans_install_tmp26576\7zip\7z.exe" x -aoa -bb1 "D:\license\WINX64.7z" "-oC:\Program Files\ANSYS Inc"' terminated after 1 attempts with the following error(s):
    Unknown error
  Exit Code: 2
ANSYS installation: So Sep 20 00:04:22 2020
Revision: 2020 R1
    Unknown error
  Exit Code: 2
  ###### Warnings/errors #######
  Warnings/errors were encountered while running the ANSYS License Manager configuration. Please check the install_licconfig.err file in the installation directory for details.
2020/09/20 00:03:07 ...WARNING: Attempt to populate the CVD 'license_files' directory did not find a legacy ANSYS license file at the following location:
            C:\Program Files\ANSYS Inc\Shared Files\Licensing\license.dat
2020/09/20 00:03:58 ...WARNING: Because no license files were found in the following location, the 'ANSYS, Inc. License Manager' service was not able to be started.
            C:\Program Files\ANSYS Inc\Shared Files\Licensing\license_files
            The ANSYS License Management Center's 'Add a License File' link should be used to install license files and to start the ANSYS, Inc. License Manager.
            This can be accessed through the 'ANSYS, Inc. License Manager --> ANSYS License Management Center' item in the Windows Start menu/Apps page.
Opening the workbench, I can see toolboxes. Trying e.g the "Transient Thermal" toolbox, I get the error:
and after "OK"
In the „Client ANSLIC_ADMIN Utility“ I can't see any licenses (I saw some a few installations ago, but right now they don't appear).
What might be my issue?
    Is this machine the correct machine for the license file ? i.e., is the first line in the license file show this machine information ?
    There is something odd because your License Manager is not running but it seems you are using license from another machine but that license just has expired TECs
