Error when opening HFSS
How to solve when this error happen? This error message came out when using HFSS module. The OS using is Linux. Is there any advise?
    I would recommend to use HFSS/AEDT outside of the Workbench unless you really need Workbench for some unique functionalities.
  • Still need to use Workbench for the project and also has turned off security and firewall software but it does not work.
    What version is this ?
    If you open up a blank Workbench session, then insert HFSS module and double click on Geometry cell, does it launch AEDT successfully ?
  • When double click on Geometry in workbench, AEDT cannot be launched. When launched AEDT alone, it come out with error : feature has expired. flexnet error -147, -10. However, the license is still valid. The version using now is 2019.R3
  • Amal85Amal85 Member
    Hi!
    Thank you for your response. Finally we can open AEDT. This happen because of we used expired licenses key. After change to a new license key the software can be opened.
