Bolted nozzle flange project in hands on introduction to simulation by coronnel university course
i am not getting the solution and also convergence i tried many times. what will be the issue, can anyone help me out?
peteroznewman Posts: 11,404Member
1) Insert a Contact Tool under the Connections folder and then Evaluate Initial Contact Status. Are all the active contacts Closed? If not, you have to edit the Contact and set it to Adjust to Touch.
2) Under Analysis Settings, turn on Auto Time Stepping. Set the Initial Substeps to 100.
