Magnetic Braking System
I am simulating a magnetic braking system with a copper brake disc and a gray cast iron u-shaped magnet and keep receiving the following error (first photo is the initial error message and second is the actual error explained):
The Distributed ANSYS solution does not support SOLID117 elements.
 Distributed parallel processing will be deactivated for this solution.
 *** NOTE ***                           CP =      0.766  TIME= 14:38:04
 Distributed parallel processing has been temporarily disabled.
 ***** ANSYS SOLVE   COMMAND *****
 *** TREE GAUGING FOR EDGE ELEMENTS ***
