LESIZE command, LAYER1 Command not being implemented
I am trying to manually mesh something using the LESIZE command in APDL.  The documentation says that the syntax is the following:
LESIZE, NL1, SIZE, ANGSIZ, NDIV, SPACE, KFORC, LAYER1, LAYER2, KYNDIV
From what I understand, if I input a negative value for LAYER1, then the magnitude of LAYER1 should specify how many layers in the mesh have the size specified in SIZE.
For example, if I write:             LESIZE, all, 0.1, , , 1, 1, -5, ,0
then I would expect that the value of -5 in LAYER1 implies that there should be 5 rows of elements with an edge size of 0.1.  I am not observing this in the model.  So either, I have misinterpreted the meaning of LAYER1 or I am missing something.
Any suggestions to get LAYER1 working would be appreciated.  It seems like it would come in handy for my model.
Thanks!
  • jpasquerelljpasquerell Canonsburg, PAMember
    edited August 2018
    I think multiplier means 5 * 0.1 = 0.5 so 0.5 should be used as the element size for layer 1.  Is that what you are seeing?
  • joepa_2017joepa_2017 Member
    edited August 2018
    Maybe.  However, if that is the case, why not just specify the element size to be 0.5 on the line to begin with?
    edited August 2018
    This is what I'm trying to do:
    Line-Graded Layer Mesh
    edited August 2018
    My initial reply was incorrect.  See the test input below.  It appears that setting layer2 to a non-zero value is also needed to get that type of mesh.
    /prep7
    fact=5
    rect,,11*fact,,3*fact
    pcirc,2*fact,,0,360
    wpoff,4*fact,3*fact
    pcirc,2*fact,,0,360
    wpoff,4*fact,-3*fact
    pcirc,2*fact,,0,360
    asba,1,2
    asba,5,3
    asba,1,4
    et,1,200,4
    save
    lsel,s,,,5
    lsel,a,,,11,14
    lesi,all,0.1,,,1,1,-5,2,0
    esiz,1
    amesh,all
    edited August 2018
    The good news is that your code works as desired.
    The bad news is that for some reason mine does not.  I have even tried layer meshing on a very simple geometry.  When I run the following code on a rectangle, I still only get 1 layer of elements that have the desired size.  Here is a sample code from a simple rectangle; I don't see what would be incorrect with it:
    /PREP7
    RECTNG,0,10,0,-5,
    !Define element type
    et,1,plane183
    lsel,s,line,,3
    keyopt,1,1,1
    lesize,all,.05,,,1,1,-5,1,0
    aesize,1,.5
    amesh,1
    edited August 2018
    It looks like it only works when using esize rather than aesize... That's unfortunate
    edited August 2018
    Nevermind.  It looks like the layer meshing works only when using esize rather than aesize.  So, it is still possible to use if each area is meshed separately, and esize can be redefined between meshing each area.
