Cycle repetition in ansys workbench (low cycle fatigue)
Hello everybody,
I'm performing a thermo-mechanical fatigue analysis with ansys workbench.
I wanted to ask if there is a way to perform the following with ansys workbench:
  • Apply one load cycle (displacement and temperature)
  • Read an output variable which I defined (damage)
  • If this variable is lower than a defined maximum value, then repeat the load cycle
  • Increment a cycle counting variable
  • Repeat till the damage reaches a maximum value that I define.
Is this something feasible with workbench?
Thank you very much for your help!
